Activity › Forums › Blackmagic Design › import image sequence still duration issue
  • import image sequence still duration issue
    Posted by Massimo Croce on August 8, 2006 at 2:14 pm
    Hi to All
    i m importing to FCP an TGA image sequence, setting up FCP steel duration to 1 frame but
    when i drag the folder in to project the stiil duration is 0.
    setting up the duration to 2 frame the imported stiil duration is 1.
    Any solution????
    thanks
    massimo
    Apple Dual G5
    FCP 5.04
    OSX 10,4,6
    Chris Borjis replied 20 years, 1 month ago 2 Members · 1 Reply
  • Chris Borjis
    August 11, 2006 at 6:19 pm
    import your still frames to quicktime, or after effects
    then export as a 10-bit quicktime video.
    FCP doesn’t handle image sequences like every other editing system out there.
