Activity Forums Apple Final Cut Pro Legacy Import Flicker issue
  • Import Flicker issue
    Posted by Ernie Santella on October 19, 2006 at 9:13 pm
    I just received some out-of-house animation files. They were created using Animation codec, field rendered, No alpha, 720×468, 29.97, Lower-field.
    After I import them and play them, they flicker like a flipped-field dominance problem. I tried adding the ‘shift field’ filter (either +/-), but no dice, still have the same flicker.
    When you watch it on the desktop with QT player, they look fine. Any ideas how to fix this?
    Ernie Santella
    Santella Film/Video Productions
    http://www.santellaproductions.com
    Ernie Santella replied 19 years, 10 months ago 2 Members · 2 Replies
  • Bouncing Account needs new email address
    October 19, 2006 at 9:49 pm
    Just a guesss.
    What is the resolution? If the image resolution is too “large” (dense) for TV resolution, the small details can “dance” on-screen.
    Try adding:
    Video Filters > Blur > Gaussian Blur
    Set it to a very low amount and then check it on an external video monitor as you make further adjustments.
  • Ernie Santella
    October 19, 2006 at 10:54 pm
    Figured it out. Animator error. He rendered part of his animation in upper, then combined it together with something in lower and sent me something with mixed dominance.
    I thought I was crazy, but it was him! Those guys need to sleep more!
    Ernie Santella
