Activity Forums Apple Final Cut Pro Legacy IMPORT file recognized, access denied, error unknown
  • IMPORT file recognized, access denied, error unknown
    Posted by Allen Roulston on February 25, 2011 at 8:56 pm
    Greetings,
    I’m running Final Cut Studio HD (some call it Final Cut Studio 3) Final Cut Pro version 7.0.3
    When provide the files created from a download from a video camera (Canon HV30) to another person running a version of Final Cut Pro HD 4.5 and they cannot IMPORT the MOV files. They get the message :
    So then I created a H.264 version of the video, and handed that over to the other editor (using FCP HD 4.5) and he could not import that file either.
    Does this sound familiar to anyone?
    Is it some kind of backward compatibility issue?
    Thank you,
    ~ Allen
    Rafael Amador replied 15 years, 7 months ago 3 Members · 3 Replies
  • Rafael Amador
    February 26, 2011 at 1:51 am
    [Allen Roulston] “to another person running a version of Final Cut Pro HD 4.5”
    Allen
    The only HD supported format on FC 4.5 was (if I’m not wrong) DVCProHD. The codecs you are trying to edit didn’t existed as the time.
    So, or they use a newer version of FC, or you give them the files on other codec (DVCProHD, PhotoJPEG) supported by that version.
    Rafael
    http://www.nagavideo.com
  • Jeff Greenberg
    February 26, 2011 at 4:35 pm
    Yup, Raf nailed it.
    Backward compatibility isn’t an FCP thing. By the way, they’re running FCP 4.5 (which for a brief second was called HD).
    Export XML (ver 2) to get the project out- they may be able to open the XML (The project) – use the Media Manager to transcode all your HD footage to DVCProHD is the ONLY way you’ll have any compatibility at all.
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • Rafael Amador
    February 26, 2011 at 4:49 pm
    [Jeff Greenberg] ” FCP 4.5 (which for a brief second was called HD).”
    That was an smart name and a when really started to shine.
    rafael
