Activity Forums Apple Final Cut Pro Legacy Import DV footage via V1u into FCP
  • Import DV footage via V1u into FCP
    Posted by Teresa Brown on August 23, 2011 at 12:39 am
    I have DV footage I want to import using a Sony HVR-V1u. It was recorded using a standard definition camcorder. FCP7 recognizes the camera but isn’t allowing preview or import of the footage. Will I need to use a strictly std. def. camera to import this?
    Teresa Brown replied 15 years ago 1 Member · 3 Replies
  • Teresa Brown
    August 23, 2011 at 2:42 pm
    All settings appear correct. Camera indicates DVCAM format footage exporting as DV out to Final Cut – Capture preset is DV NTSC anamorphic, device control is FireWire NTSC. I’ve been working exclusively in solid state HD last couple years, so DV is rare. Final Cut recognizes & operates the camera playback just fine, the DV footage is visible on the camera’s display, but FCP’s Log & Capture gives a “preview disabled” message and error message that there is no video. I investigated threads discussing the “preview disabled” and nothing seemed relevant to this situation.
    I suspect there could be an issue that the footage was captured on an exclusively standard definition camera rather than the V1u which records HDV as MPEG, but can’t confirm if DV footage is also captured as MPEG. I can bring in a GL2 in a couple days if this isn’t doable through the V1u.
  • Teresa Brown
    August 23, 2011 at 3:37 pm
    Yes, as I just indicated, the V1u is set to export DV and that is confirmed on the camera’s display screen. The footage was recorded on a GL2, thus DV only.
  • Teresa Brown
    August 23, 2011 at 3:46 pm
    DV=standard definition, HDV=1440×1080 are the V1u options
