Activity › Forums › Apple Final Cut Pro › Import DSLR Footage into FCP X as HD1080i 24 FPS
Posted by Adam Berch on October 19, 2015 at 4:11 pmHi,
I have DSLR footage that was given to me on an External Hard-drive that was shot with a Canon camera.
Is it possible, to import those clips into FCPX as HD1080i 24 FPS instead of ProRes?
If so, How?
FCP 10.2.
Bret Williams replied 10 years, 10 months ago 4 Members · 3 Replies -
Noah Kadner
October 19, 2015 at 5:39 pm -
Doug Metz
October 19, 2015 at 7:58 pm[Adam Berch] “I have DSLR footage that was given to me on an External Hard-drive that was shot with a Canon camera.
Is it possible, to import those clips into FCPX as HD1080i 24 FPS instead of ProRes?”
In FCPX preferences, look at the Import tab, and make sure “Create Optimized Media” is unchecked. This way, it will simply re-wrap the H264 DSLR footage. The footage will then appear in FCPX with the settings that were in use on-camera when the footage was shot (frame size / interlaced or progressive / framerate).
I assume H264 for DSLR… haven’t seen any other encoding for those cameras. At 24fps, you should have progressive footage.
Doug Metz
Anode
Bret Williams
October 19, 2015 at 9:49 pmDon’t have it optimize on import and they’ll come in as h264 or whatever format they were originally (possibly avchd). There is no such thing as 24i so you can’t make them 1080i 24FPS. If they were shot 24p then just drop them in an interlaced sequence to have interlaced pull down added. But they’ll still look progressive. If you really wanted to jump through hoops you can use optical flow and some exporting importing to create the missing fields out of thin air. But you don’t want to do this. https://www.fcp.co/final-cut-pro/tutorials/1731-creating-interlaced-video-from-progressive-footage-in-final-cut-pro-x
