Activity Forums Adobe After Effects Import AVID Audio export into A.E. or viceversa.
  • Import AVID Audio export into A.E. or viceversa.
    Posted by Michele Poggi on July 7, 2011 at 11:13 am
    I found that the way A.E. and Avid manage Audio levels are completely different. Assuming Avid as the better and professional one, actually an exported audio from Media Composer become extremely HIGH on volume in A.E., this is quite a mess because the Render engine of A.E. is perfect, but I can’t say the same of Media Composer.
    Is there any way to be able to integrate the two programs on the same project/work? Some kind of.. Well, “expression” like from C° to F°? Or am I doing the wrong thing/looking in the wrong direction?
    “Cinetica Video” post-producer.
    Michele Poggi replied 15 years, 2 months ago 2 Members · 2 Replies
  • Erik Waluska
    July 7, 2011 at 2:53 pm
    Sounds like you may have your levels set too high in Avid or something because there shouldn’t be any difference in volume levels between the two apps. What is the peak db level in Avid? I would suggest you try to import a music track or something that you know has the levels balanced correctly into a fresh Avid project with default settings and then export it out and test it in AE and compare the db levels.
  • Michele Poggi
    July 10, 2011 at 9:36 am
    I’ll try. The fact is that on A.E. the Peak is “0db” while on Avid that’s the middle of the Audio Tool, because the objective for mixing is usually keep it from 0 to 6. I didn’t really understand A.E. in this for now.
