Activity › Forums › DaVinci Resolve › import audio
  • import audio
    Posted by Glenn Sakatch on August 12, 2011 at 6:35 am
    I have a 3 min music video i’m starting on in Resolve Mac. I have an XML, and all related media (prores 422) and have spit out an AIF from FCP for the project.
    The XML comes in great, (video wise) but not the audio. If i go to my timeline and select audio options, enable, and select my aif file, it comes looks like it jumps into my conform edl window, but i still can’t figure out how to get it to play with my timeline. The files that show up in the confrom edl window are labeled M2 under the # column. there seems to be more than one that have appeared in the window, but i can’t seem to be able to do anything with them.
    any ideas.
    Glenn
    Rohit Gupta replied 15 years, 1 month ago 2 Members · 1 Reply
  • Rohit Gupta
    August 12, 2011 at 6:39 am
    You have to generate a single audio track, and when you play in the color page, it will play it in sync with the video.
    The audio comes from the Decklink audio outputs, and also as embedded audio in the SDI stream.
