Activity Forums Maxon Cinema 4D Import audio to Cinema 4D
  • Import audio to Cinema 4D
    Posted by Gon Perdigao on October 16, 2008 at 1:22 pm
    Hi there how can i import audio to cinema 4D?
    I went to the maxon support and they say to do :
    1. Create Sound Track: File>New Track>Sound
    2. Select the default sequence on the sound track.
    3. In the Attribute Manager, click the ellipses […]button and load the desired sound file from disk.
    But i don’t have that option in file.
    I have cinema 4D R10.506. Can you help me?
    Thanks a lot
    Gon Perdigao replied 17 years, 3 months ago 3 Members · 5 Replies
  • Nolan Scott
    October 16, 2008 at 9:11 pm
    First open some project (at least a cube… or else…)
    Open the Timeline / File / Add Special Tracks / Sound…
    In the Attributes-Manager import your sound…
    Make sure it’s either .aif or .wav / 44100 Hz 16 Bits… (otherwise it won’t show up)…
    Play your sound…
    In the viewport check “Play Sound During Animation”…
    Cheers
    Nolan
  • Gon Perdigao
    October 16, 2008 at 10:23 pm
    thanks a lot 🙂 it work just fine
  • Claudia Magnesa
    June 11, 2009 at 1:36 pm
    Why it doesn’t work for me? The option File>Add Truck is not clickable. Please help, thank you
  • Claudia Magnesa
    June 11, 2009 at 1:55 pm
    I think I got it, I din’t know I had to select a keyframe.
  • Gon Perdigao
    June 11, 2009 at 4:22 pm
    create a new object , then go to window —> time line —> select the object and then go to file add special track and in the botton is sound.
    In the right side it’ll appear the buuton to load the sound
