Activity Forums Adobe Encore DVD Import as folder bug?
  • Import as folder bug?
    Posted by Matthew Polack on December 21, 2007 at 12:58 am
    I’m using Encore 2 and am attempting to simply import a folder of photos as an asset: (as I have done numerous times in Premiere)
    I am following the steps as described by the help section:
    Make sure that the Project panel is active, and do one of the following:
    Choose File > Import As > Asset.
    Double-click any empty area below the asset list.
    Navigate to the file or files that you want to import, select them, and click Open. To import the contents of a folder, select the folder and click Import Folder.
    My problem is that when I click on the folder I simply do not see any option anywhere to “Import Folder”…the only option is “Open”
    I can only import the files manually into a folder I have first manually created…
    Is this a bug in Encore 2? or alternatively What am I missing here? Thanks
    Jeff Bellune replied 18 years, 8 months ago 2 Members · 1 Reply
  • Jeff Bellune
    December 21, 2007 at 3:45 am
    This is not possible in Encore CS3, and the CS3 help files do not reference this technique.
    I strongly suspect that it’s not possible in 2.0, either, and that the 2.0 help files are incorrect.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
