Activity › Forums › Adobe After Effects › Import a Premiere Pro Project vs Dynamic linking
Posted by Jim Bachalo on September 7, 2011 at 3:56 pmHi
Can anyone explain to me why and when you might choose to import a Premiere Pro Project vs use Dynamic linking from within PPro?Local is the new global
Michael Szalapski replied 15 years ago 3 Members · 2 Replies -
Ben G unguren
September 7, 2011 at 5:30 pmYou only need Dynamic linking when you are going to go back and forth between apps. Sometimes I’ll use Premiere to assemble and arrange the clips, then take all that into AE and never come back to Premiere. In that case Dynamic linking isn’t necessary.
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Michael Szalapski
September 8, 2011 at 4:55 pmI usually import the Premiere project. I rarely use Dynamic Link. I don’t need to keep going back and forth and tweaking things. I make the edit, do my AE work, finish audio work and compress! No need for linking things. And I prefer having all the clips seperate in AE.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
