Activity Forums Adobe After Effects import a comp from a different project ?
  • import a comp from a different project ?
    Posted by Incredible Bud on September 5, 2007 at 8:22 am
    I’ve done some animated backgrounds that i’m using in different project. (a kind of stock shot!)
    I’ve to modify it a little bit to adapt it to the speed, colour…of each project.
    I didn’t find anyway to import the entire project into my new project.
    So I’m copying and pasting each solid from each comp and precomp.
    Is there any faster or easier way ?
    Thank you
    Incredible Bud replied 18 years, 12 months ago 3 Members · 3 Replies
  • James Zwadlo
    September 5, 2007 at 8:48 am
    I like to prerender it,then import it, runs faster that way
  • Jim Arcon
    September 5, 2007 at 11:09 am
    FILE > IMPORT > FILE then pick your other aep project file.
    This brings in the other project in a folder with the project name. You can then select individual comps and make any needed modifications.
  • Incredible Bud
    September 5, 2007 at 4:45 pm
    Thanks a lot, both of you and specialy to Jim.
    I didn’t even try it before. To scary for me !!!
