Activity Forums Apple Final Cut Pro Legacy iMove > FCP > AE is there a better way?
  • iMove > FCP > AE is there a better way?
    Posted by Jason Davids on June 18, 2009 at 3:06 pm
    I think there are a few problems with my workflow to say the least and was wondering if anyone could offer some suggestions on how to get the best quality video out at the other end.
    I start by using iMovie to turn my raw 1920 footage into something useable via the AIC, which I gather is pretty lossless?
    Then more often than not I’m forced to bring it into FCP because I love the SmoothCam filter and unfortunately can’t seem to get the same results from magic bullet stabilise in AE…
    I then export these stabilized clips out using export > quicktime > current settings (I assume this is the best/lossless way of doing it)
    Then play in AE until I’m done.
    I wish I could skip out the FCP step as I feel its probably effecting the quality of my product, but I really like SmoothCam 🙂
    Anyway any tips or suggestions on how things can change for the better would be very much appreciated! Oh and if it helps my primary output is vimeo.
    Many thanks
    Jason
    Shane Ross replied 17 years, 2 months ago 2 Members · 1 Reply
  • Shane Ross
    June 18, 2009 at 5:34 pm
    [Jason Davids] “I start by using iMovie to turn my raw 1920 footage into something useable via the AIC, which I gather is pretty lossless? “
    You gather wrong. AIC is a lossy codec. What is this footage? HDV? AVCHD? FCP can capture HDV as native HDV, or with a trick as ProRes via firewire. AVCHD can be imported as AIC or ProRes in FCP, and ProRes is by far the better choice. It too is a conversion, but it is a far less “lossy” codec.
    [Jason Davids] “I’m forced to bring it into FCP because I love the SmoothCam filter “
    Did you know that iMovie ’09 now has a built in stabilizing filter?
    [Jason Davids] ” then export these stabilized clips out using export > quicktime > current settings (I assume this is the best/lossless way of doing it) “
    That is correct.
    ANY TIPS? Get iMovie ’09 and use it’s built in stabilization.
    Shane
