Activity › Forums › DVD Authoring › Imgburn is taking 8hrs to burn and verify. Yikes!
  • Imgburn is taking 8hrs to burn and verify. Yikes!
    Posted by Peter Slabysz on January 8, 2013 at 9:43 pm
    I’m using a Verbatim BD-R and a LG 6X writer to do a MPEG Disc Image to Blu-Ray burn. Why is it taking 8 hours to do this? Log attached. BTW, I did 2 discs with the same results. I swear I did one that only took 15 minutes, although it was H.264 instead of MPEG. I went with MPEG b/c I was having audio issues and wanted to insure playback compatibility. Thanks for the help.
    https://f1.creativecow.net/5181/imgburn-log
    Jon Geddes replied 13 years, 8 months ago 2 Members · 1 Reply
  • Jon Geddes
    January 9, 2013 at 12:15 am
    Hi Peter,
    Looking at your log file, it appears you are having serious issues with the discs you are using or the drive you are using, though it looks like you recently had a successful burn in the 20 minute range? Maybe you are having issues with the usb disconnecting on your external burner. You might want to try lowering the burn speed, using a different usb port/cable, using an internal burner, and/or using better quality media. Falcon Media Pro brand discs are the best (better than Verbatim and Taiyo Yuden, and come in hub-printable glossy water resistant)
    Jon Geddes
    http://www.precomposed.com
