Activity › Forums › Adobe Premiere Pro › Images with text in premier
  • Images with text in premier
    Posted by Iiipgciii on May 15, 2007 at 3:42 pm
    When I use an image with text in a Premier project with video, when I export it, the image is blurry and unreadable, how can I fix this? The quality of the image is high enough.
    Vince Becquiot replied 19 years, 4 months ago 2 Members · 1 Reply
  • Vince Becquiot
    May 15, 2007 at 5:35 pm
    Make sure you turn of the scale to frame size option if you are doing any kind of zooms, pans.
    What export setting are you using?
    Finally what are you playing back the footage on?
    Vince
