Activity Forums Apple Final Cut Pro Legacy Images shake after rendering
  • Images shake after rendering
    Posted by Richard Haddad on September 3, 2008 at 4:51 pm
    We noticed this new issue after using FCP for some time on one of our workstations.
    Even on a slide show with still frames and simple Ken Burns motion the canvas displays the sequence just fine until we render it. Once rendered, the image starts to jump up and down slightly — as if you are looking out the window of a fast car on a bumpy road.
    We’ve tried resetting all the preferences to match other computers running successfully, and this is the only workstation that has this playback error.
    Our next step will be to reload FCP onto the machine if necessary, but I would love to solve this mystery if anyone has seen this happen before.
    Heidi Laubscher replied 14 years ago 12 Members · 15 Replies
  • 15 Replies
  • David Bogie
    September 3, 2008 at 5:57 pm
    [Richard Haddad] “Our next step will be to reload FCP onto the machine if necessary, but I would love to solve this mystery if anyone has seen this happen before.
    Probably not a solution. Reloading FCP rarely cures anything but you can always trash your most recent QT receipts and force those updates to reload form apple’s software update system.
    You’ve got to figure out if the rendered QT file is the problem or if it’s the machine or the display on the machine. If it’s the QT file itself, an up and down, one-pixel shake should be visible as a field problem if you show your canvas at 800%.
    bogiesan
  • Richard Haddad
    September 3, 2008 at 6:22 pm
    This error is occurring even when viewed in the timeline and before exporting the file. For example, when we drag a photo into the timeline and set a motion frame, it looks great. If we then pull down from the menu bar — Sequence>Render All>Both — and then we play it in the canvas, we see the image jumping up and down. This jumping and shake stays in the exported products whether we export to QT or as an .flv file using a plug-in.
    If you think throwing away something related to QuickTime will help, I am happy to try it. I’m just a little confused on exactly what to throw away and were to find it. This is a new issue that suddenly appeared about two weeks ago. Before that we used this workstation regularly with no render errors.
  • Stu Hibberd
    September 5, 2008 at 1:33 am
    Here’s a long shot. Is your render mode set to 10bit? You can find this in the sequence settings under video processing. If so try changing it to 8bit and see if that makes difference.
    cheers,
    Stu
  • Mathew Broughton
    March 10, 2009 at 12:46 am
    I’m having the same issue and nothing seems to work! I’m making a simple side show with some Ken Burns effects and cross dissolves. Soon as I render and try to play back in the timeline the images shake up and down? I thought this might just be in the timeline but it occurs when I export as well? Any new solutions anyone came up with?!?! Seems like it should be a simple fix but i can’t figure it out 🙁
  • Richard Haddad
    March 10, 2009 at 7:31 pm
    The only thing that we can guess is that it was related to RAM. We ended up expanding the RAM in that workstation and the issue stopped. We never figured it out for sure, but the shaking stopped.
  • Joe Ginty
    October 31, 2009 at 1:43 am
    have the same problem when it’s burned but images are perfect in f.c.p. and studio. they are stills i took with the camera during filming. play great on a pc or mac but on tv all the stills except the ones from stills camera shake.loads of ram to spare too but just cant figure it.tried everything in iphoto,fcp and compressor but to no avail.
    please help
    joe
  • Phillip Wiggins
    December 12, 2009 at 6:13 pm
    I have had the same issue on the last two slideshow’s. when i remove the Ken Burns effects i built, it seems to go away. looks as if the resolution is wrong or when it moves at a slight angle the res. lines start to show. it really seems to pick out the white in the images.and it’s not on all the images’ only just a few . I have tried using Anti Alias filter with no resolve. Can’t seem to be able to change the resolution.My system i’m using is an 17″ mac book pro with max ram. I would think that a slideshow would be something that that FCP could handle.
    p.s can someone give advice on what might help.
    Thank you in advance
    Phillip at Wigginsproductions
  • Lina Katan
    February 7, 2010 at 7:36 pm
    I’ve had the same problem, this solved it:
    right click(ctrl click) the image on the timeline -> go to speed -> uncheck frameblending.
    venlig hilsen
  • Shannon Lloyd
    January 26, 2011 at 2:41 am
    You are truly the man. This solved my problem also, a slideshow for my producer’s father’s memorial that I had to complete today. Thanks!!
    Shannon Lloyd
    Verdugo Media
  • Shannon Jennissen
    April 2, 2011 at 7:53 pm
    Unfortunately the frame blending solution didn’t work for me, but using the pen tool and doing dissolves manually that way did. Just thought I’d add in case someone else ran into the same problem!
