Activity Forums Apple Final Cut Pro Legacy images into fcp
  • images into fcp
    Posted by Nuisance33 on November 28, 2006 at 11:58 pm
    hello
    im new to this post.
    but i wondering the best way to import files from adobe illustrator.
    i tried using just an AI file and it comes in kind of distorted.
    i also try using a targa and that was distorted as well.
    aslo i have another question of a different topic.
    i was wondering how to export my sequences to dvd..i exported
    to mpeg 4 and then moved into idvd but it will not allow me to
    remove there themes (curtains and other backgrounds) i was told
    that i have to my video as a IMG in order to put it on a dvd..
    i greatly appreciate any help.
    thanks.
    Jonezetta replied 19 years, 10 months ago 3 Members · 4 Replies
  • Jonezetta
    November 29, 2006 at 12:10 am
    i have exported files as hi rez jpegs and also pdfs and it has worked well.
    I think if you use iDVD you have to use one of their templates. But you should be able to tweak those pretty well. I’ve personally bene able to do a lot with those and just drag and drop video or images into the windows to create my own presentations. IF you want anything more , you have to go to a program like DVD Pro in order to have complete creative control.
    I usually export DV content using “Export as Quicktime Movie” and select DV-NTSC48K. Then you can just choose import in iDVD to bring it in. IF the video is too large to bring it in as DVNTSC 48, then maybe try the Apple’s Compressor 2 (if you have it) to limit the file size. There’s many option there.
  • Nuisance33
    November 29, 2006 at 5:53 am
    thanks so much.
    it gives me an error when importing the pdf’s or it changes the color?
    is there any reason for this?
    thanks again.
  • Walter Biscardi
    November 29, 2006 at 5:56 pm
    [nuisance33] “it gives me an error when importing the pdf’s or it changes the color?”
    Are they CMYK? They should be RGB
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Jonezetta
    November 29, 2006 at 8:51 pm
    yeah, make sure they are RGB and it should fix it. Also if you get any flickering or image instability, try using the flicker filter or deinterlacing filter in Final Cut Pro effects…
