Activity › Forums › Adobe Encore DVD › Images in Slideshow are horizontal instead of Vertical
  • Images in Slideshow are horizontal instead of Vertical
    Posted by John Perez on February 5, 2017 at 6:49 pm
    Several pix in my slideshow are incorrectly rotated. ‘Should be vertical instead of horizontal. The are properly rotated in Photoshop. Why is this, and how can I fix? Thanks!
    As always thanks so much to you guys…Johnny In Orlando
    John Perez replied 9 years, 7 months ago 2 Members · 3 Replies
  • John Perez
    February 8, 2017 at 4:32 am
    Can i get a witness?
  • Jeff Pulera
    February 8, 2017 at 8:59 pm
    Hi Johnny,
    So are you trying to make a slideshow directly in Encore, importing stills? Never tried that, always do my work in Premiere then export MPEG-2 DVD for use in Encore.
    First suggestion would be – make all the stills a uniform 720×480 for DVD. If you have odd sizes, maybe that is causing issues, like if image is taller than it is wide? Or just make the slideshow in Premiere to start with, a lot more flexibility with adding effects and music and such.
    Jeff Pulera
    Safe Harbor Computers
  • John Perez
    February 10, 2017 at 11:46 am
    Thanks so much, Jeff. Yes, was trying to use the Slideshow feature in Encore. I will do in Premiere…
