Activity › Forums › Apple Motion › Image with Alpha Channel not showing up in Motion 4
  • Image with Alpha Channel not showing up in Motion 4
    Posted by Michael Barnes on December 30, 2012 at 2:16 pm
    Hello,
    I found a sun glow image in a stock library that I would like to use as a transition between shots in FCP 7.
    I imported the image into Motion 4. The image reportedly has an alpha channel. The problem is that the sun glow is not showing up in Motion.
    I tried playing around with View>channel alpha settings in Motion and this did not work. Any suggestions on being able to view the image in Motion, then export with alpha to play in FCP?
    Thanks.
    Michael Barnes replied 13 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
