Activity Forums Adobe Illustrator Image to Solid
  • Image to Solid
    Posted by Matt Gillman on August 6, 2012 at 5:51 pm
    Right, I have a problem. I have this is image (JPEG), first I opened it in PhotoShop and used colour range to select the parts I wanted, copied them to a new PSD, saved it, opened the PSD through illustrator and I am now trying to convert that image contents into a solid.
    The attached image shows what i’m dealing with. Is there a quick way to get all those collated circles selected and changed to individual solids?
    thanks
    Matt
    Vincent Rosati replied 14 years ago 2 Members · 1 Reply
  • Vincent Rosati
    August 21, 2012 at 12:23 am
    Sounds like you probably want to do a live trace.
    Select the raster object, then click the Live Trace button up under the main menu.
    Here’s a thread that goes into some detail about live trace…
    https://forums.creativecow.net/thread/245/862297
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
