Activity › Forums › Apple Final Cut Pro Legacy › Image skips when I play sequence back full screen.
  • Image skips when I play sequence back full screen.
    Posted by Rory Keenan on February 19, 2010 at 11:01 pm
    (I’ve put all the specs of footage & computer below)
    I’m guessing this is a RAM problem.
    However I’m not sure if I need to increase RAM . . . . OR . . . . do i need to increase V-RAM . . . OR . . . . is it a video card . . . . or a combination???
    Or is a totally different issue???
    Here’s what happens:
    The motion skips when played in the sequence window full screen.
    I import the clips and put them in a sequence with settings that match the raw footage.
    When played in the viewer window the motion does not skip.
    Motion does not skip in the sequence window if the sequence window is small.
    When I play the raw clips in Quicktime (full screen) there is no skipping.
    When I export something from the sequence timeline and play it in Quicktime full screen there is no skipping.
    So, is my guess about RAM / V-RAM / Video Card correct??
    If so which one is it (RAM, V-RAM or Card) & what can I do about it??
    The owner has a Kona 3 card lying around . . . will this solve the problem??
    If so can I put it in myself . . . or is it something we should hire a tech to do??
    I’m importing clips shot on a Cannon MarkII.
    Raw footage stats:
    30fps
    1920x1080p
    H.264
    Computer Stats:
    4gig of Ram
    CPU
    Model Name: Mac Pro
    Model Identifier: MacPro3,1
    Processor Name: Quad-Core Intel Xeon
    Processor Speed: 2.8 GHz
    Number Of Processors: 2
    Total Number Of Cores: 8
    L2 Cache (per processor): 12 MB
    Memory: 4 GB
    Bus Speed: 1.6 GHz
    Boot ROM Version: MP31.006C.B05
    SMC Version (system): 1.25f4
    Serial Number (system): G88233EKXYK
    Hardware UUID: D13B0947-AC41-5073-982E-DD925614C0E7
    VIDEO CARD
    ATI Radeon HD 2600:
    Type: display
    Driver Installed: Yes
    Bus: PCI
    Slot: Slot-1
    Vendor ID: 0x1002
    Device ID: 0x9588
    Subsystem Vendor ID: 0x106b
    Subsystem ID: 0x00a6
    Revision ID: 0x0000
    Link Width: x16
    Link Speed: 5.0 GT/s
    Michael Gissing replied 16 years, 7 months ago 2 Members · 1 Reply
  • Michael Gissing
    February 19, 2010 at 11:17 pm
    The issue of trying to use a non edit codec like H264 in FCP has been covered here so many times.
    Do a search for Canon 5D and the correct workflow will be revealed.
