Activity › Forums › Adobe Illustrator › Image size issues
  • Image size issues
    Posted by Matthew Scott on July 7, 2008 at 1:45 am
    I’m using Illustrator cs 1.1.0.0 and am having problems with creating a file with certain dimensions. When I make a new file, and select the dimensions of it to be 70×100 pixels, everything seems to be ok until I export it as a bmp or jpeg or png. When I do that, and then check the info of the newly created file, the dimensions become completely different.
    What am I doing wrong?
    Matthew Scott replied 18 years, 2 months ago 2 Members · 5 Replies
  • Jeff Kelley
    July 7, 2008 at 5:04 pm
    Check your resolution when you export. Since your saving a vector image into a jpg, Illustrator can convert it into different sizes. I think if you set your resolution to screen it will come out the size you created it in.
    Jeff
    http://www.willinois.com
  • Matthew Scott
    July 7, 2008 at 10:14 pm
    I’m not seeing anything about resolution when exporting. I’m setting it to 150 dpi, but I don’t really know what that means, that’s just what I know I need it to be at.
    Basically what I’m doing is this: I created an image without constraining the size, and now I need to make a thumbnail out of it. The thumbnail needs to be 70×100 pixels and under like 200 kb I think. But I can’t seem to do this and also when I scale the image from the original size, it scrunches everything up that I drew even though I am scaling the width and height proportionally.
  • Jeff Kelley
    July 8, 2008 at 2:34 pm
    Here is what I was talking about
    I think 72 should give you a 1 to 1 ratio
    Jeff
  • Matthew Scott
    July 15, 2008 at 4:36 am
    I tried it but it didn’t work. I appreciate your help though. Any other ideas? Maybe not even using Illustrator – I could somehow save it in another program maybe?
  • Matthew Scott
    July 15, 2008 at 5:55 am
    I figured it out. I needed to click on save for web. There I was able to change the dimensions
    Thanks for your help Jeff!
