Activity Forums Apple Motion Image size for Motion
  • Image size for Motion
    Posted by Brad Harris on August 15, 2010 at 4:18 pm
    Hello,
    I am working on a project in FCP 7 that is DV/DVCPRO-NTSC, 29.97 fps, 720 x 480, Pixel aspect is NTSC-CCIR 601. I want to use a image (a screen grab from google maps) in my project. I am going to import the image into Motion 4 as I want to make the image move or pan and zoom nothing crazy just a simple move across the screen. I am not sure what the right size the image should be. The image is a screen grab from google maps street view so I will bring it into photoshop but not sure what dimensions I should use. I know that it has to be larger then my sequence setting which is 720×480 but how much larger?
    Thank you,
    Brad
    Stephen Smith replied 16 years ago 5 Members · 14 Replies
  • 14 Replies
  • Noah Kadner
    August 15, 2010 at 4:20 pm
    Depends how much you want to zoom in- just try it….
    Noah
    Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!
    Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II and Canon 7D.
    Learn DSLR Cinematography.
  • Mark Spencer
    August 15, 2010 at 4:29 pm
    If it’s a screen grab then there’s nothing to decide – it is what it is.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Brad Harris
    August 15, 2010 at 4:34 pm
    I can still enlarge it in photoshop to an extent.
  • Gareth Randall
    August 18, 2010 at 6:52 am
    What I’d do is look up the relevant Google Maps page on the computer with the highest-res display I could find, and take a screen grab of that. On my MacBook Pro that would be 1680×1050, which at 72dpi should give you plenty of room to pan and zoom in a 720×480 project. Or am I missing something?
  • Stephen Smith
    August 18, 2010 at 1:28 pm
    Google maps are copyrighted. Take a look at Google Maps Pro. https://www.google.com/enterprise/earthmaps/earth_pro.html
    It’s maps are not water marked and give you a lot more options. Best of luck.
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
  • Brad Harris
    August 18, 2010 at 1:36 pm
    Hello,
    Thank you for your responding to my post. You need to have a company to register for the Google Maps Pro trial, and I don’t have my own company. I would love to try the trial but not sure If I can do it without a company?
    Aside from that what about just a regurlar photo that was teken using a digital camera. What should I resize the image to before I bring into Motion and make it move? I have still yet to figure out how I can zoom in or out of a image taken from camera?
    I appreciate all of your help!
    Brad
  • Stephen Smith
    August 18, 2010 at 1:44 pm
    Brad,
    Are you a student and this is a student project?
    As for stills, always make it 72dpi. I like to make it a little bigger then the size of the project I’m working on. If I’m going to zoom in a lot then I make it a lot bigger the the size of the project I’m working on. I guess what I’m saying is, for me it is not an exact science. I have a broadcast monitor so if it is not big enough I’ll know real quick. I’ve accidentally brought in super huge pictures and they work great except for the render in FCP time.
    Stephen Smith
  • Brad Harris
    August 18, 2010 at 2:06 pm
    No I am not a Student. The size of my FCP project is 720×480 so that would be the size of my Motion project right? I guess that there is no way I can download the Google Maps Pro Trial right?
    Thank you,
    Brad
  • Stephen Smith
    August 18, 2010 at 2:21 pm
    I highly recommend you create a business, even if you only do free lance work. If you get sued for a project you did they can come after you. If you have a business they can only come after the assets in the businesses name. So your personal assets are protected. A business licensee in my state is only $15. You can form a company on legalzoom for really cheap. Something to think about.
    But yeah, you would want your still to be bigger then 720 x 480. The further you are going to zoom the bigger you would want your image to be.
    Stephen Smith
  • Stephen Smith
    August 18, 2010 at 2:30 pm
    Also,
    If you are going to zoom in a big distance such as the Whole USA to the city of Boise you will need to use multiple maps. Here is how it works. You have a map of the US. Then a map of Idaho. Then a map of Boise. You take the Idaho map and lay it on top of the USA map. Create a mask around the Idaho map with a feathered edge to blend it into the USA map. Do the same thing with the Boise map. Animate the camera so it zooms from the whole USA to Boise. That will help maintain the quality when you reach the final destination that would have been lost had you just had one map to work with. Hope this makes sense and best of luck.
    Stephen Smith
