Activity Forums Apple Final Cut Pro Legacy image size changes when played
  • image size changes when played
    Posted by Pedro De la fuente on August 20, 2008 at 11:47 am
    Hey guys, going trough some funny FCP (v 6.0.4) behaviour here. I set up my sequence in a size and compression that works perfectly well when I drag the footage in. The problem is that when I press play the image changes size and gets out of proportion, being bigger than the canvas and I assume this isnt right.
    Technical notes:
    video I am dragging to the timeline
    – size: 1024×576
    – fps: 25fps
    – compressor: DV – PAL
    – square pixel
    timeline settings:
    – frame size: 720×576 (DVPAL 5:4)
    – Pixel Aspect Ratio: Pal – CCIR 601 (720×576) ANAMORPHIC (tried with “square pixel” and doesnt work either)
    -Compressor: DV – PAL
    Tks in advance for your time. Any tips will be much appreciated.
    Best,
    Pedro
    Pedro De la fuente replied 18 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
