Activity Forums Apple Final Cut Pro Legacy Image sequencing!
  • Image sequencing!
    Posted by Sean Hargreaves on November 16, 2008 at 7:02 pm
    I rendered an animation in Lightwave 3d. Each frame was a png file. I then imported the files into QuicktimePro as an image sequence. I have 120 frames, therefore 120 files. They are 1500 x 750 each.
    1) Quicktime Pro would not let me sequence all the files for some reason, therefore I imported them in sections, and therefore when I loaded them into Final Cut Express, they had to be 3 Quicktime files as opposed to one.
    2) When I play the movie in Final Cut it appears to go black for maybe one frame between these three Quicktime files.
    How do I get a smooth flow between the three files?
    Rafael Amador replied 17 years, 9 months ago 2 Members · 3 Replies
  • Rafael Amador
    November 17, 2008 at 3:54 am
    You can import as stills. Set “1 frame” the Stills duration in your Preferences. Import the folder with the still and drag all of them to a new sequence. You can use this sequence just as a clip and drag it to any other sequence.
    Don’t forget to rise the “Still Cache” in the Preferences too.
    Cheers,
    rafael
    http://www.nagavideo.com
  • Sean Hargreaves
    November 20, 2008 at 8:31 pm
    Where do I set the frame duration in my preferences? Are you talking about Final Cut Express preferences? I looked there, I don’t see where I can set the frame duration.
  • Rafael Amador
    November 24, 2008 at 5:28 am
    Hi Sean,
    Sorry but I was talking about FC Pro.
    rafael
