Activity Forums Apple Final Cut Pro Legacy Image Sequences
  • Image Sequences
    Posted by Brian Thomson on August 3, 2009 at 10:03 pm
    I am trying to export some image sequences using the export quicktime conversion menu. The footage is HDV1080i and therefore 16×9. The export result gives me a 4×3 (squished) ratio result. I am betting that I am missing something pretty easy. Thanks in advance.
    Brian Thomson
    Jeremy Garchow replied 17 years, 1 month ago 2 Members · 3 Replies
  • Jeremy Garchow
    August 3, 2009 at 10:15 pm
    Do you have after effects?
  • Brian Thomson
    August 3, 2009 at 10:21 pm
    Yes
  • Jeremy Garchow
    August 4, 2009 at 3:23 pm
    It is much easier to bring the QT movie in to AE, then render an image sequence from there.
    You will get better quality as well.
    Jeremy
