Activity › Forums › Adobe Premiere Pro › Image sequence XML export
  • Image sequence XML export
    Posted by Chris Gunningham on November 14, 2011 at 11:29 am
    Here’s what i’m doing: import several .png sequences into premiere as numbered stills. Edit them on the timeline. Export FCP XML. Import XML into FCP. FCP is only seeing the 1st frame of the .png sequences (for the duration of the clip). Is there a work around for this?
    Chris Gunningham
    Chris Gunningham replied 14 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
