Activity Forums Adobe After Effects Image sequence never exports enough frames
  • Image sequence never exports enough frames
    Posted by Sam Baum on November 6, 2013 at 1:43 pm
    Hi all
    I’m trying to render out an image sequence from AFX. But if I import the sequence back in and lay it over my original animation it appears shorter. Is there a setting I am missing that locks in the frame rate? I’m sure I’m beinbg stupid, but I can’t seem to fix this!
    Any help would be great!
    S
    Sam Baum replied 12 years, 10 months ago 3 Members · 3 Replies
  • John Kaley
    November 6, 2013 at 2:02 pm
    Go into Preferences/Import and make sure the “Sequence Footage” is the same as your timeline’s framerate.
    Or you select your imported sequence and go into “Interpret Footage/Main and manually conform to the desired framerate.
    Also, consider using a proxy instead of re-importing. In the render queue/output module, select “Set Proxy” in the Post-Render action menu.
  • Roland R. kahlenberg
    November 6, 2013 at 2:05 pm
    Check your Preferences->Import settings to ensure that the default Sequence Footage fps is set to appropriately. Ideally, this the fps should be set to the fps that you most commonly use – hence it is a setting for a default.
    You can override this setting in the Interpret Footage dialog for individual footage in the Project Panel.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Sam Baum
    Thanks John! That’s the ticket!!!
    S
