Activity Forums Adobe After Effects image sequence issue
  • image sequence issue
    Posted by Eugene Perepletchikov on September 23, 2006 at 6:18 am
    I am converting a few shots into image sequences to be put into Maya for match moving. I tried importing an avi but Maya didnt accept it. Anyway, the issue is that After Affects automatically names the files in the seqence as name_0001, name_0002 etc. This is an problem with Maya, as to recognise an image sequence it requires the following naming convention: name.0001, name.0002 etc.
    Is there a way to change AE’s naming convention for my image sequences?
    Eugene Perepletchikov replied 20 years ago 4 Members · 4 Replies
  • Matt Silverman
    September 23, 2006 at 7:31 am
    When you name the file, just replace the underscore with a period. If you want to permanently change this, I think that there is a way in the text prefs, but not positive…
  • Lars Bunch
    September 23, 2006 at 3:38 pm
    In the render queue, there is a small arrow right next to “output to” where you set the filename. Click on that and select “custom” This will give you a window that allows you to change the naming convention.
    At any rate, it works this way in AE 7.
    Hope this helps,
    Lars
  • Vince Becquiot
    September 23, 2006 at 6:13 pm
    Or use this little thing to rename them all to whatever format you need: https://www.bulkrenameutility.co.uk/Main_Intro.php
    Vince
  • Eugene Perepletchikov
    September 24, 2006 at 5:20 am
    Thanks a lot guys, problem solved!
    Lars, your suggestion did the trick.
    Cheers
