Activity Forums Apple Motion Image Sequence
  • Image Sequence
    Posted by John Craven on December 21, 2010 at 2:36 am
    I want to import an image sequence that has a transparent background. When I import it into Motion the transparent background turns into a black background.
    I have other image sequences where the transparent background stays, but for some reason not on all of them.
    Any suggestions?
    John Craven replied 15 years, 8 months ago 2 Members · 4 Replies
  • Mark Spencer
    December 21, 2010 at 2:40 am
    Did you check Motion’s interpretation of the alpha channel (Shift-F)?
    Are all your images in the sequence 8-bit RGB? All the same codec, e.g. PNG or TIFF?
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • John Craven
    December 21, 2010 at 2:48 am
    I’m not too familiar with the how to work with the Alpha Channel. I do know both of my image sequences are Tiff. I tried (shirt-f) while the image sequence was selected but nothing happened.
  • Mark Spencer
    December 21, 2010 at 2:55 am
    Shift-F is a shortcut that reveals the media in the Media tab of the Project pane and also selects the Media tab in the Inspector – you could just click on them but it saves some steps. In the Media inspector you can choose how Motion interprets the alpha channel. Try the different options.
    Mark Spencer
  • John Craven
    December 21, 2010 at 3:05 am
    Got it. Alpha type was None/Ignore. I changed it to PreMultiplied-Black. Thank you very much.
