Activity Forums Adobe After Effects image sequence
  • image sequence
    Posted by Marilyn Jimenez on December 30, 2009 at 5:12 pm
    I imported a portion of a video into AE CS3 as an image sequence in order to clean up a piece of dirt on a hose that is being wound up for storage(for a training video that I did as volunteer service). I placed the image sequence into the timeline as as single composition and used the clone tool to clean up 309 frames! I did not use the sequence layers command when I dragged the image sequence into the timeline (which I found out I was supposed to do from an earlier posting), so all the layers are stacked up and only the very top layer exports. Needless to say, I do not want to lose all of the clean up work that I did and would like to export the sequence either as a image sequence or as a Quicktime movie. Thank you in advance for your advice.
    Marilyn Jimenez replied 16 years, 8 months ago 59,986 Members · 1 Reply
  • Marilyn Jimenez
    December 31, 2009 at 1:20 am
    Thank you very much. It worked!
