Activity Forums Apple Motion image packages for 3D?
  • image packages for 3D?
    Posted by Brian Cooney on February 12, 2011 at 5:45 pm
    Does anyone know of a resource to purchase images for a 3-D project? What I mean is, maybe there are packages that offer several perspectives of the same subject? In my case, a chimney cleaning commercial. Client wants to see the house from a distance (back on the lawn) and then have the camera pull in and then up and over the roof to look down at the chimney at a 45 degree angle…
    Kinda stuck here… thanks!
    Sacha Thomas replied 15 years, 6 months ago 7 Members · 22 Replies
  • 22 Replies
  • Mark Spencer
    February 12, 2011 at 5:48 pm
    Turbosquid.com is a great resource for 3D models of all kinds
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Brian Cooney
    February 12, 2011 at 6:05 pm
    Thanks Mark!
  • Brian Cooney
    February 12, 2011 at 6:38 pm
    does anyone know if Apple Motion can import and work with .max, .3ds, .ma, or .obj files? Might be best using 3D psd.. can’t find the answer in literature ..-B
  • Brian Cooney
  • Mark Spencer
    February 12, 2011 at 6:44 pm
    Only with Cinema4D can you export 3D data, lights, and cameras for use in Motion.
    Mark Spencer
  • Brian Cooney
    February 12, 2011 at 6:45 pm
    thanks for the info!
  • Arnie Schlissel
    February 12, 2011 at 9:13 pm
    Motion does not import any 3D geometry. It sounds like your client is looking for someone to do this in C4d, Lightwave, Max or Maya.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Brian Cooney
    February 12, 2011 at 9:29 pm
    yeah.. the company I contacted “TurboSquid” did say they offer 3D models in .psd format. That might work hey?
  • Zak Peric
    February 13, 2011 at 9:00 am
    Zaxwerks (ProAnimatorFX) can import .obj and it si a 3d plugin for apple motion and final cut. You can do quite a lot of things with it. However if you are looking for a complex animation than yu are best to use some sort of 3d program, bug learning curve.
  • Brian Cooney
    February 13, 2011 at 1:06 pm
    thanks. I’ll check that out.
Page 1 of 3
