Activity Forums Adobe Premiere Pro Image overlays come out blurry
  • Image overlays come out blurry
    Posted by Jeff Bellamy on April 18, 2013 at 3:51 pm
    Looking for a little help.
    I author a DVD each month for a company and we add image overlays to movie trailers. It has a banner along the top of the trailer and along the bottom. (Movie title, movie cover, copyright line and a couple small logos)
    We use video that is 720p so I built it in Premier Pro CS6
    Video Settings I use in PP CS6
    DV – NTSC > Widescreen 48kHz
    General
    Editing mode: QuickTime DV NTSC
    Timebase: 29.97fps
    Video Settings
    Frame size: 720h 480v (1.2121)
    Frame rate: 29.97 frames/second
    Pixel Aspect Ratio: D1/DV NTSC Widescreen 16:9 (1.2121)
    Fields: Lower Field First
    Audio Settings
    Sample rate: 48000 samples/second
    Default Sequence
    Total video tracks: 3
    Master track type: Stereo
    Audio Tracks:
    Audio 1: Standard
    Audio 2: Standard
    Audio 3: Standard
    The video comes out pretty decent (I realize because we author to DVD it wont be HD)
    When creating the overlays I use Photoshop CS6 I have tried so many different ways and they come out really nice IN Premier Pro, but as soon as I author to a DVD they are blurry.
    I have tried a bunch of the presets in PS but the most common one I try is:
    Preset > Film & Video > HDV/HDTV 720p/29.97
    Width 1280
    Height 720
    Resolution 72
    RGB Colour 8 Bit
    Colour Profile: Don’t colour manage thus Document
    Pixel Aspect Ratio: Square Pixels
    Does anyone see what I am doing wrong? Or could it be that I am authoring in 720p HD and then trying to burn it to a DVD, cause when I author to a Blu-ray it looks fantastic, it’s just downgrading to DVD it sucks.
    Ivan Myles replied 13 years, 4 months ago 3 Members · 6 Replies
  • Joseph W. bourke
    April 18, 2013 at 4:42 pm
    Try upping the Resolution from 72 to maybe 150. While 72 ppi was fine when we were all working in SD (720 x 480 or thereabouts), once you go to a higher resolution (1280 x720), things start to quickly look shabby and pixelated. Give it a try, and let us know…
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Joseph W. bourke
    Try upping the Resolution from 72 to maybe 150. While 72 ppi was fine when we were all working in SD (720 x 480 or thereabouts), once you go to a higher resolution (1280 x720), things start to quickly look pixelated. Give it a try, and let us know…
    Joe Bourke
    Bourke Media
  • Jeff Bellamy
    April 18, 2013 at 4:50 pm
    Thanks Joe I appreciate the help. Running a test now at 150 and 300 fingers crossed.
  • Ivan Myles
    April 18, 2013 at 5:04 pm
    [Jeff Bellamy] “and 300 fingers crossed”
    That’s a lot of fingers! 🙂
  • Jeff Bellamy
    April 18, 2013 at 5:10 pm
  • Ivan Myles
    April 18, 2013 at 5:35 pm
    The blurriness might be a byproduct of chroma sub-sampling. If so, it will be difficult to eliminate. Try exporting a few frames with 4:2:2 and uncompressed RGB (“None”) codecs to verify.
