Activity Forums Adobe After Effects Image looks bad on camera movement
  • Image looks bad on camera movement
    Posted by Chad Ashton on February 21, 2007 at 5:09 am
    I have imported a psd file into after effects 720×486. Image looks great until I make camera zoom in or out then the image ripples during the movement of the camera. What do I need to do to make image not do that during camera zoom.
    Abulazm replied 19 years, 7 months ago 4 Members · 4 Replies
  • Mylenium
    February 21, 2007 at 7:01 am
    What do you mean by zoom? Scaling the image? Really zooming with a 3D camera? anyway, your resolution is insufficient when you zoom in. you probably need to work with much larger resolutions.
    Mylenium
    [Pour Myl
  • Mark
    February 21, 2007 at 11:57 am
    Sound like you are seeing pixels….this is normal if you are indeed scaling or moving closer to the image with a camera. As Milenium suggested, try working with higher res originals.
  • Chad Ashton
    February 21, 2007 at 7:30 pm
    the image is 720×480 with 72 dpi. I tried with fields on, lower first and it came out great.
  • Abulazm
    February 21, 2007 at 11:34 pm
    chad .. the problem is when you zoom or scale the image you loosing the quality.
    as Mylenium & mark said you have to use the same image with hight resolution.
