Activity Forums Apple Final Cut Pro Legacy Image judder on DV DVD (created with HDV footage)
  • Image judder on DV DVD (created with HDV footage)
    Posted by Samlondon on September 18, 2006 at 3:49 pm
    Hey all. I’ve created a DV project using HDV footage. I created a QT movie (with a slight judder in some places but not that noticable) and then a DVD. On much of the pan and zoom footage there is an awful judder and some pixelation issues also. Is there anything I can do to sort this out?? Will changing the frame rate help?
    Mark Maness replied 19 years, 11 months ago 4 Members · 3 Replies
  • Trevor Ward
    September 18, 2006 at 5:11 pm
    is the footage slo-mo? That can cause the jitters. You can try a deinterlace filter on the specific footage.
    -trevor ward
    orlando, fl
  • Jeremy Garchow
    September 18, 2006 at 5:27 pm
    What versions of everything are you using? Compressor can guess the wrong field order sometimes.
    Jeremy
  • Mark Maness
    September 18, 2006 at 8:41 pm
    Jeremy is absolutely correct. The latest update to Compressor has really screwed up some things. One thing is being able to detect field order. Go back and re-compress in Compressor but this time change your field order of the default. It happened to me recently.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
