  • Posted by Erik Dell on July 30, 2010 at 11:32 pm
    Hello,
    I am having issues with images not appearing on my website: https://www.barriegolfcourses.com
    The 2 top banners are not appearing, nor is the background.
    I built this site in Dreamweaver CS5, and all the images have been uploaded and linked together.
    The weird thing is that the images work if you click on any of the golf course profiles :S … so that leads me to believe they are just saved in the wrong place but I doubled checked that and it seems to be fine ….
    Other then that I have no idea why the images arent working, and I need help! (if you need to see code just ask)
    Abraham Chaffin replied 16 years, 2 months ago 2 Members · 1 Reply
  • Abraham Chaffin
    July 31, 2010 at 12:46 am
    When I view the source of your site you have code that says stuff like this:
    body {
    background-color: #FFF;
    background-image: url(file:///C|/Users/Sean/Barrie%20Golf/Back%20Ground.jpg);
    background-repeat: no-repeat;
    The “file:///C|/Users/Sean/Barrie%20Golf/Back%20Ground.jpg” is an absolute path to a file on your machine. You need to make sure you build web pages with your site setup correctly first. Check the images that aren’t showing up and try to change the path.
    Absolute Path on Web:
    https://www.barriegolfcourses.com/Barrie%20Golf/Back%20Ground.jpg
    Absolute Path for your Site:
    Absolute Path Relative Path to your subdomain.
    Relative Path to your current file
    etc.
    Abraham
