Activity Forums Adobe Encore DVD Image file button highlight problem
  • Image file button highlight problem
    Posted by Bill Kimzey on December 14, 2009 at 9:29 pm
    I write a Blu-ray project to an iso image file from the build menu. Then, from the image file, burn a disc. The highlights are correct; all looks fine. Immediately thereafter, closing out the burn completed dialog, I burn a second disc. This time the highlights are displaced, and do not match up with the buttons. The pop-up menu is also scaled down from its normal size to something smaller, and displaced from the bottom to somewhere in the middle.
    I’ve tried this 3 times. First disc successful; second disc, not successful.
    Again, this is from an iso image file, so this seems like it should be impossible, with the point being that it’s the same image.
    I see several posts of others having highlighting issues, but really, I don’t understand how this one can happen.
    Running Snow Leopard and CS4.
    Thanks for any insight.
    Bill Kimzey replied 16 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
