Activity Forums Apple Motion Image/clip distributed on rectangles
  • Image/clip distributed on rectangles
    Posted by Ralph Manns on October 5, 2020 at 2:35 pm
    Hello Motion gurus out there.
    I need a push in the right direction. I want to create an effect like the one that I have found in a slideshow template for Motion/FCP (https://videohive.net/item/slideshow-on-the-blocks/19236765).
    An image or a clip is distributed on squares, which are sides of small cubes. While the cubes move to a different location they rotate with an amount of 180 degrees and when they settle down the cubes back squares form a different image/clip.
    How can this be done?
    I have tried it with a replicator and sequence replicator, but then I have to cut my images sources in fitting squares before importing them in Motion and that doesn’t work with clips.
    I would be very thankful, if someone can point me in the right direction. Thanks.
    Ralph.
    Ralph Manns replied 5 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
