Activity Forums Adobe After Effects image buffer errors
  • image buffer errors
    Posted by Ubermensch_6696 on May 30, 2007 at 10:08 am
    Hi! I just wanted to ask for some help regarding error prompts that pop up mainly when I’m rendering material on AE.
    On a specific project, I had to composite HD material and at times had to multiply them (as in crowd multiplication). While rendering the following prompt appears:
    After Effects error: could not create 1280×720 image buffer (7::39)
    after clicking ok, another prompt appears:
    After Effects error: bad parameter passed to effect callback (37::49)
    Naturally the render ends at that specific point in the timeline.
    What could cause this? Is it an AE7 problem or is something wrong with my system? Incidentally, I’m using a Intel MacPro (2×2.66G dual core intel xeon with 4G memory)
    On another machine of the same configuration, other image buffer errors appear – 2560×1440 and even 720×480 image buffers cannot be created.
    I’m hoping you guys can shed light on this problem. It really throws a wrench into the workflow and because certain projects are graphics heavy, such a problem can’t be tolerated.
    Thanks again.
    LES
    Ubermensch_6696 replied 19 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
