Activity Forums VEGAS Pro image and clip automation for new media added to project and timeline
  • image and clip automation for new media added to project and timeline
    Posted by Fred Speece on July 9, 2009 at 12:22 am
    I capture jpg image sequences from my video game, I would like to automate or speed up the below process that I currently do.
    I import the jpg sequences with File ->Import ->Media. [found out I can hit the button above my media for this]
    I then check “Open still image sequence”, then hit ok.
    the clip’s properties to be set as:
    Frame Rate: 25
    Field Order: None
    Pixel Aspect: 1.0 square
    alpha: none [all these should turn into clip default I believe?]
    then when I drag the clip on to the timeline, I change the Properties to:
    -Disable Resample <-- the "by pass motion blur" button doesn't seem to stop "Smart Resampling" from applying (the default option for media). -increase playback rate to: 2.0 -add a velocity envelope, and set that envelope to 200% -have the file not loop but shrink itself down so it doesn't repeat. (I drag the file down to 25% the length) I do all this because I capture 100FPS and export 25fps to maintain smoothness, but I don't want extra motion blur (as I do the blurring in game) Any ideas on how to minimize the number of clicks I need to do? I did look pretty hard in the Options->Preferences. I don’t know anything about scripting in vegas but willing to learn if it will help. appreciate any ideas.
    https://www.shaolinproductions.org/
    John Rofrano replied 17 years, 2 months ago 3 Members · 6 Replies
  • John Rofrano
    July 9, 2009 at 10:39 am
    You could script the last couple of steps after you import the image sequence to make it one click but you need to know how to program in C#, VB, or JavaScript to write a script. I could write you a script to do this unless you want to try and tackle it yourself.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Theo Van laar
    July 9, 2009 at 10:40 am
    Did you check already the Vegas production Assistant to quickly set up new projects?
    https://www.sonycreativesoftware.com/vegasproassist
    Theo
  • Fred Speece
    July 9, 2009 at 9:33 pm
    If you don’t mind scripting some of this that would be awesome. I don’t know how to script.
    Thanks for the Production Assistant suggestion I will check that out also.
    oh and i’m currently using vegas 8 Pro.
    timeline: https://img38.imageshack.us/img38/9674/vegase.jpg
  • John Rofrano
    July 10, 2009 at 12:34 pm
    Here is a script that performs the procedure you explained:
    1. Disable resample
    2. Set playback rate to 2.0
    3. Disable looping
    4. Add velocity envelope at 200%
    5. Adjust length to 25%
    I don’t know why you set the playback to 2x and then add a 2x velocity envelope. Why not just set the playback to 4x? (it’s the same thing)
    Anyway, here is the script: (save is at AdjustPlayback.cs in your Script Menu folder.)
     * Program: AdjustPlayback.cs
     * Description: This script will change the playback rate of the selected events
     * Author: John Rofrano
     * Revision Date: July 10, 2009
    using System;
    using Sony.Vegas;
    class EntryPoint
        public void FromVegas(Vegas vegas)
            foreach (Track track in vegas.Project.Tracks)
                if (track.IsVideo())
                    foreach (VideoEvent videoEvent in track.Events)
                        if (videoEvent.Selected)
                            videoEvent.ResampleMode = VideoResampleMode.Disable; // disable resample
                            videoEvent.PlaybackRate = 2.0; // double the playback rate
                            videoEvent.Loop = false; // turn off looping
                            // create a velocity envelope
                            Envelope velocityEnvelope = videoEvent.Envelopes.FindByType(EnvelopeType.Velocity);
                            if (velocityEnvelope == null)
                                velocityEnvelope = new Envelope(EnvelopeType.Velocity);
                                videoEvent.Envelopes.Add(velocityEnvelope);
                            // get the default point and change it 2.0
                            EnvelopePoint velocityPoint = velocityEnvelope.Points[0];
                            velocityPoint.Y = 2.0;
                            // adjust the event length to 1/4 it's original size
                            videoEvent.Length = new Timecode(videoEvent.Length.ToMilliseconds() / 4.0);
    ~jr
  • Fred Speece
    July 10, 2009 at 7:07 pm
    most of my clips I change the speed on at different points to sync the events in the video to points in the audio. I could do 4x + add a velocity envelop and set at 100%, or 2x + 200%. I assume the resulting quality of the video will be the same?
    Thanks for the script, I will try it out this weekend. The commenting is very helpful also, thanks.
    Another question: is their such a thing as an audio velocity envelope that will work similar to the video version?
  • John Rofrano
    July 11, 2009 at 12:21 am
    Yes, either way the quality should be the same. I kinda thought you might be changing the velocity so using both makes sense.
    As for audio, no there is no velocity envelope equivalent. 🙁
    ~jr
