Activity Forums Avid Media Composer iMac running AMD Radeon HD 6970M 2GB GDDR5
  • iMac running AMD Radeon HD 6970M 2GB GDDR5
    Posted by Peter Hordylan on July 20, 2011 at 11:07 pm
    Hi Folks
    I’m going to purchase a new i7 iMac and can’t decide if I should buy the AMD Radeon HD 6970M 2GB GDDR5 upgrade. Will I have any issues running MC? Are there advantages? Any help would be appreciated. Thanks!
    Lance Bachelder replied 15 years, 1 month ago 3 Members · 2 Replies
  • Marianna Montague
    July 21, 2011 at 2:12 pm
    Hi Peter
    You really need to check out the Macintosh specifications before you forge ahead… The card we tested and approve with this system si the ATI Radeon HD 57500. No ide what you might experience if you go another route.
    Go to the knowledge base and check this out.
    https://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=362919
    Marianna
    marianna.montague@avid.com
  • Lance Bachelder
    July 22, 2011 at 5:25 pm
    The 5750 is not available in the i7 iMac. Avid always seems to be a generation or two behind in their specs. The 6870 should work fine as it uses the same drivers as the 5750 – just has way more hardware power. I’d opt for the 2 GB version just to future proof your purchase a bit more.
    Lance Bachelder
    Writer, Editor, Director
    Irvine, California
