Activity Forums Apple Final Cut Pro Legacy iMac compatible with FCS2
  • iMac compatible with FCS2
    Posted by Amy Wilson on March 13, 2009 at 6:18 pm
    I’m looking to purchase an iMac for an assistant editor to use on a compressed HD project and just looking for some advice on its configuration. I’ve looked over the requirements but the only thing I’m unsure about is which iMac config to get based on the video card. Also as far as connecting to drives, is the best connection offered by an iMac the single fw800?
    Amy
    Kent Stipp replied 17 years, 5 months ago 2 Members · 1 Reply
  • Kent Stipp
    March 13, 2009 at 8:12 pm
    Greetings,
    If your set on an iMac I’d look at the 24″ 3.06 ghz with the GForce GT130 Video card. To address the drive connection there is only 1 firewire 800 the rest are USB so the firewire would be best there you might look at the G-Raid3 series.
    Hope this helps a bit
    Life Begins at 155mph
    Catch it edit it View it
    3am Studios llc.
    3amstudios.org
    Sharedsummitsfever.com
