Activity Forums Adobe Premiere Pro imac 27″: connecting a second monitor and a client monitor but no Thunderbolt 3 port left for external HD.
  • imac 27″: connecting a second monitor and a client monitor but no Thunderbolt 3 port left for external HD.
    Posted by Olivier Prudhomme on November 3, 2017 at 6:27 am
    2017 iMac 27″, 3.4ghz. 32gb RAM
    I am able to connect the client monitor and the second monitor using the 2 available USB-C (thunderbolt 3) ports.
    Now I don’t have a port for my external drive(s).
    I don’t want to use USB2 for the ext. HD because of the speed limitation compare to Thunderbolt 2.
    Any work around this pb?
    Thx
    Los Angeles – TV Promo Editor – FCP – AVID
    Olivier Prudhomme replied 8 years, 6 months ago 2 Members · 5 Replies
  • Andy Patterson
    November 3, 2017 at 11:39 am
    [Olivier Prudhomme] “I don’t want to use USB2 for the ext. HD because of the speed limitation compare to Thunderbolt 2.”
    Is it USB 2 or USB 3.1 2nd gen? The website site says “USB 3.1 Gen 2 (up to 10 Gbps)”. It is not as fast a Thunderbolt 3 but there is a decent amount of bandwidth there. Enough for 4, 5, 6 even 7 hard drives striped together. 12 hard drives striped together would create a bottle neck.
  • Olivier Prudhomme
    November 3, 2017 at 3:16 pm
    That would be good news.
    I just still can’t find out on Apple website if it’s gen 1 or gen 2…
    But I’ll keep looking
    Thx!
  • Andy Patterson
    November 3, 2017 at 8:51 pm
    It say USB 3.1 gen 2 on Apple’s website.
  • Olivier Prudhomme
    November 3, 2017 at 11:02 pm
    I can’t find it on Apple website.
    All I can read is:
    Four USB 3 ports (compatible with USB 2)
    Two Thunderbolt 3 (USB-C) ports with support for:
    DisplayPort
    Thunderbolt (up to 40 Gbps)
    Thunderbolt 2, HDMI, DVI, and VGA supported using adapters (sold separately)
    10/100/1000BASE-T Gigabit Ethernet (RJ-45 connector)
  • Olivier Prudhomme
    November 3, 2017 at 11:04 pm
    USB 3 ports
    Your iMac has four USB 3.0-compliant ports. You can connect compliant USB 3.0, USB 2.0, and USB 1.1 devices to these ports. Learn more about using USB devices with Mac computers.
