Activity Forums Maxon Cinema 4D I’m not sure if I should be cloning or fracturing this?
  • I’m not sure if I should be cloning or fracturing this?
    Posted by Chad Demoss on January 20, 2017 at 6:31 pm
    I tried cloning a row going on the z axis copying that clone and offsetting it. Then putting both clones into another clone and cloning those along the x axis. This all worked as I thought it would but now I wanted to put a random on this but seeing as I have two clones inside of the clone I’m randomizing its just randomizing rows of the clones instead of each individual hexagon. Im not sure how I would make this grid of hexagons all in one clone?
    My other though was to make a bunch of Hexagon splines and put it on a flat surface, extrude them and then fracture it but for some reason I’m running into problems.
    what would be the simplest way to make this? Here is what I want the final result to look like.
    Jim Scott replied 9 years, 7 months ago 2 Members · 10 Replies
  • 10 Replies
  • Chad Demoss
    January 20, 2017 at 8:51 pm
    Ok I couldn’t figure this out cloning it so i used fracture and it worked now I need to effect the falloff area to the shape of a cloud. I put a shader effect on it but when I try to put a custom image it doesn’t work. Here it is with a linear gradient.
    here is how i want to project the shader on the top of the fracture
  • Jim Scott
    January 20, 2017 at 10:38 pm
    If you have R18 you can use a Cloner with the Honeycomb Array to create your grid of hexagons.
    With a previous version you can use a Cloner in Grid Array mode with your hexagon and a null as children to create an alternating pattern. Use the Mode>Per-Step (above “Size”) to add clones:
    10971_gridarray.c4d.zip
  • Chad Demoss
    January 20, 2017 at 11:42 pm
    Thanks Jim
    Looking at the file I’m not sure I totally understand this but with this or the fracture file I made I still need to know how to make a custom area for the random to effect. I assume with the shader. Linear gradient is working but when I load my own greyscale image in it isn’t working at all.
  • Jim Scott
    January 21, 2017 at 12:53 am
    Are you using R18?
  • Chad Demoss
    January 21, 2017 at 1:09 am
    Ok I know what i was doing wrong now. I was trying to go into the shader >custom shader >load image. Instead I changed the shader to “color” then made a new material, loaded image into color channel and put the material on the shader, made the texture flat mapping and sized the map.
    Im wondering can I load a quicktime movie into the color channel, or a sequence of images?
  • Chad Demoss
    January 21, 2017 at 1:10 am
    No R16 unfortunately.
  • Jim Scott
    January 21, 2017 at 1:15 am
    You should be able to load a movie wherever you can load an image. Give it a shot.
  • Jim Scott
    January 21, 2017 at 1:17 am
    Here’s my version using a cloner and two Shaders – one with the image and the other with noise.
  • Chad Demoss
    January 21, 2017 at 1:18 am
    Thanks for your help Jim!
  • Jim Scott
    January 21, 2017 at 1:19 am
    I’m not sure I helped much, but I’m glad you got it figured out.
