Activity Forums Apple Final Cut Pro Legacy I’m losing my mind with EDIT TO TAPE!!!
  • I’m losing my mind with EDIT TO TAPE!!!
    Posted by Brian Pitt on February 7, 2007 at 8:19 pm
    I am trying to do what should be a simple task. I have blacked a DVCPRO tape and I’m trying to get short, 30-45 second clips starting at every one minute of time code (clip 1 plays at 1:00:00, clip 2 plays at 2:00:00 etc.)
    Here is what I’m doing. I am in the Edit to Tape window. I set my in point to 1:00:00 and drop in my first clip. The only option I have is assemble edit. When I choose that, I get a window that says roughly “ready for playback…click OK.” When I click OK, the deck navigates to the correct spot and begins recording. The problem i that when it starts recording, New time code is written. The time code that is being written in not anything I have assigned. What am I doing wrong?
    John Pale replied 19 years, 7 months ago 8 Members · 13 Replies
  • 13 Replies
  • Paul Coull
    February 7, 2007 at 8:33 pm
    Is there no insert edit option? Assemble edit overites the timecode.
    Try doing a three-point edit, that should allow the insert option to be available.
    grafxflow
    grafx that flow!
  • Joe Paolo
    February 7, 2007 at 8:36 pm
    At the deck, switch your TC settings to interal regenerate.
    joe
  • Chris Tompkins
    February 7, 2007 at 8:50 pm
    With our DVCPRO deck I have to go into the menu and set the “Time Code Regen” to off’
    Then, exit menu and set the desired new time code start
    Then, go back into the menu and set the Time Code Regen to on’
    Let us know how u make out
  • Bouncing Account needs new email address
    February 7, 2007 at 8:51 pm
    What DECK?
    Yes, you must use INSERT to do what you are attempting.
    ASSEMBLE is not designed for “coming OUT” of an edit cleanly (glitches, especially in the TC, are likely).
    Also, INSERT is designed not to need to write Timecode during the edit.
  • Chris Tompkins
    February 7, 2007 at 8:53 pm
    I don’t think our deck will do insert edit – DVCPRO Panasonic Aj-D650
    We just do Assemble
  • Mark Maness
    February 7, 2007 at 10:01 pm
    Wirh my experience… I’d have to say that Edit To Tape is a waste in FCP UNLESS you are using BetaSP.
    Anything digital… you must use Print To Video. Set your machine to Regen and if you are using an AJA product, set your starting timecode in the Control Panel. I do this every week, at least twice a week. Works just fine.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    February 7, 2007 at 10:04 pm
    [chris] “I don’t think our deck will do insert edit – DVCPRO Panasonic Aj-D650
    We just do Assemble”
    In that case, there is no reason to fully stripe a tape.
    You’d only need to go to just past, say, the first 2 minutes.
    After that, to do what you want to do, you’ll need to just let the tape “roll” (in black) AFTER each short program until the TC reaches just past the next ‘minute’ point (where you will then make the next Assemble Edit.)
    As was said, ASSEMBLE records over any previous TC (or lack thereof) on a tape.
  • Brian Pitt
    February 7, 2007 at 10:15 pm
    I’m not sure why I’m not getting the Insert edit option? I am using a DVCPRO AJ-D455 Deck. In the user manual, it says that the deck is upposed to be able to do assemble and insert edits. I can’t find anything in the menu that needs to be changed…
  • Brian Pitt
    February 7, 2007 at 10:43 pm
    That fixed it!!! Thanks Joe!
  • Tj Shank
    February 7, 2007 at 11:35 pm
    We use Edit To Tape every day, with digiBeta, BetaSP, HDCam, DVCam (basically any and all edit-capable Sony decks). Works just fine. The previous post is correct. Stripe some black at the head of the tape with the TC you need. Stripe PAST the edit in point. Then, make sure your deck is in TC Regenerate mode, back up to the blacked part of the tape, enter an in point, and assemble edit.
    tjs
