Activity Forums Adobe Premiere Pro I’m having a heck of a time exporting the right video format that I shot with my RX100-II
  • I’m having a heck of a time exporting the right video format that I shot with my RX100-II
    Posted by Richard Boswell on December 17, 2014 at 7:37 pm
    First — I’m a total rookie. I’m a photoshop/illustrator guy but am just learning premiere and after effects. I shot a movie last year while I was in Thailand and I’ve spent the last few months periodically working on editing it.
    The good news – it’s finished.
    The bad news – it renders horribly. The playback isn’t too bad on my computer but once I upload to vimeo or youtube, it looks like total crap.
    My original footage looks great.
    When I right click on a clip in Premiere, this is what I see under properties:
    File Path: X:\Raw Import\2014\Thailand\20140324-20140324220741.MTS
    Type: MPEG Movie
    File Size: 49.9 MB
    Image Size: 1920 x 1080
    Frame Rate: 29.97
    Source Audio Format: 48000 Hz – compressed – Stereo
    Project Audio Format: 48000 Hz – 32 bit floating point – Stereo
    Total Duration: 00:00:25:15
    Pixel Aspect Ratio: 1.0
    Here are my sequence settings:
    https://i.imgur.com/q1ZzHi0.jpg
    Here are my export settings:
    https://i.imgur.com/iN6toKF.jpg
    When I google the problem, I see neverending confusion about interlaced/deinterlacing, MTS2 formats, 1080/30 vs. 1080/60, etc…. I’m so confused! I know that if I hit the “match sequence settings” I get horrible combing on moving objects, but outside of that I’ve tried a few other formats and the result always seems to be far lesser quality than my original footage.
    What should I be exporting this as to upload to Youtube or Vimeo?
    View post on imgur.com
    Ivan Myles replied 11 years, 8 months ago 3 Members · 4 Replies
  • Shane Ross
    December 17, 2014 at 9:37 pm
    [Richard Boswell] “The bad news – it renders horribly. The playback isn’t too bad on my computer but once I upload to vimeo or youtube, it looks like total crap.”
    So….the compressed export looks fine when played on your computer…not the raw camera files, but the export you make, right? Because YouTube and Vimeo recompress what you upload…EVEN IF you use a YouTube or Vimeo setting in Media Encoder.
    Shane
    Little Frog Post
  • Richard Boswell
    December 18, 2014 at 12:10 am
    Thanks for the reply. I really think there’s more going on than just the results of Youtube/Vimeo compression. The rendered video (even before uploading) looks considerably worse than my source footage. Would it help if I linked to source files vs. rendered files instead of screenshots of my settings?
  • Richard Boswell
    December 19, 2014 at 2:07 pm
    I’ve created a test output of just a single clip using different settings. I’ve also included the source file. Maybe someone can tell me where/why it’s going wrong? I wouldn’t think with h264 with a similar file size to the original source should be so lossy?
    https://www.filedropper.com/outputtests
  • Ivan Myles
    January 4, 2015 at 2:17 pm
    [Richard Boswell] \”I\’ve created a test output of just a single clip using different settings… https://www.filedropper.com/outputtests\“
    Sorry, that link does not show the test file.
    Are there a lot of quick cuts in your edited file? You can always try encoding at higher bitrates (20-40 Mbps) with a maximum bitrate at least 1.5x the average setting. It might not impact the re-encoded YouTube file, but it will help with troubleshooting.
