Activity › Forums › Apple Final Cut Pro Legacy › I’m getting a green screen instead of a picture when capturing.
  • I’m getting a green screen instead of a picture when capturing.
    Posted by Gnostic on May 23, 2005 at 1:26 am
    I have a G5, FCP HD, an AJA io, and two Ocean Matrix switchers to switch between my DSR-1500 DV deck and UVW-1800 Beta deck.
    I’m running a component signal from both decks into the switcher then into the AJA io. I’m also doing DV50 NTSC.
    This settup has been working fine, both mechanically and visually, but today I tried capturing from the Beta deck and the upper two-thirds of the capture window is green and the lower third is pixilated pink and yellow lines.The cables are all correct, and I trashed and reloaded the preferences and they are correct. The settings have worked fine up until today. I’m stumped.
    Mike
    Pdr replied 21 years, 4 months ago 2 Members · 3 Replies
  • Pdr
    May 23, 2005 at 1:38 am
    Hi Mike
    Out of interest, when you capture something, does the captured clip look normal, or does it also have these coloured artefacts?
    Regards
    Peter
    Peter Dominic Ryan – Freelance Editor
    raycity* media – pdr@raycity.com
  • Gnostic
    May 23, 2005 at 3:24 am
    I had assumed that the captured picture would be the same artifacts I saw in the window, so when you asked the question, I went in and called up log and capture, and surpriseingly, all was back to normal, even though I didn’t change anything, the picture comes through fine. For how long, I don’t know. I had tried everything I could think of before and nothing doing.
    I’m still puzzled.
    the best, Mike
  • Pdr
    May 23, 2005 at 3:41 am
    Sounds like gremlins to me!
    Regards
    Peter
