Activity Forums Apple Motion Illustrator to Motion with edit point enabled
  • Illustrator to Motion with edit point enabled
    Posted by João Cunha on March 2, 2012 at 12:47 pm
    Hi.
    I just created a toon in illustrator and used meshes to color it. Now I’d like to import it to motion to animate it. How can I make the export/import so that I keep my mesh point editable in motion?
    Thank you.
    Mark Spencer replied 14 years, 6 months ago 2 Members · 3 Replies
  • Mark Spencer
    March 2, 2012 at 2:20 pm
    There’s a great script that will turn any simple paths in Illustrator into Shapes in Motion, complete with control points:
    https://www.motionsmarts.com/downloads.html
    Here’s a short movie on how to use it:
    https://pixelcorps.cachefly.net/mbks_061_540p_h264.mov
    However, it only works on simple paths, one at a time, so it may not work for what you are trying to do.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • João Cunha
    March 2, 2012 at 2:31 pm
    I’ve already tried that script but it asks me to select shapes when I select my mesh. I don’t think I’ll be able to make it work.
    Do I need to start the toon over again? There is not a chance I can control the main points of the shape to deform it a bit and animate them in motion?
    Thank you Mark.
  • Mark Spencer
    March 2, 2012 at 3:38 pm
    Like I said, it only works with simple shapes. Sounds like you need to use the Puppet Tool in After Effects to do what you want.
    Mark Spencer
