Activity Forums Adobe After Effects Illustrator to AFX color issue
  • Illustrator to AFX color issue
    Posted by Francis Gelinas on August 27, 2008 at 6:16 pm
    On several occasions, I’ve had problems with colors when importing Illustartor file in AFX, they just arent the exact same…
    I guess it has something to do with the color settings of both Illustrator ans AFX, but I cant seem to find the way.
    Does someone know the workaround?
    Francis
    couleur.tv
    Brian Walsh replied 18 years, 1 month ago 2 Members · 1 Reply
  • Brian Walsh
    August 27, 2008 at 6:29 pm
    Francis,
    You might be working in CMYK colorspace in Illustrator, while After Effects works in RGB colorspace. Switch your colorspace in AI to RGB, see if that helps.
