Activity › Forums › Adobe After Effects › Illustrator to AE
  • Illustrator to AE
    Posted by Tayres on September 6, 2007 at 8:17 pm
    I have a path in Illustrator CS that I would like to use as a mask in AE 6.5…In Illustrator, I select and “copy” the path to the clipboard. In AE, I create a solid, select it, and the “paste” option is grayed out. How can I get this path into AE?
    Kevin Camp replied 19 years ago 2 Members · 4 Replies
  • Tayres
    September 6, 2007 at 8:37 pm
    I tried this > AICB option in the Files & Clipboard section of the Adobe Illustrator Preferences…
  • Kevin Camp
    September 6, 2007 at 8:57 pm
    well, it sounds like you are set up right…. are you only selecting vector data when you choose copy? if you are selecting raster data too, it may be causing problems….
  • Tayres
    September 7, 2007 at 2:33 pm
    Not quite sure what EXACTLY is going on….Preferences maybe? But it let me paste onto a layer that is a composition. From there I copied it to the solid. I don’t think I shoud have this problem but, I’m not familar enough with this process to figure out what is happening…Thanks for the help.
  • Kevin Camp
    September 7, 2007 at 3:08 pm
    [tayres] “But it let me paste onto a layer that is a composition”
    that seems even more strange…
    if you want to troubleshoot this, open ae and illustrator. then create a new illustrator file (make the artboard 640×480) and create a simple shape in a new illustrator file, like a square. copy the shape, then go to ae, make a new comp, make a new solid (comp size) and paste. if paste is greyed out, try the keyboard shortcut.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
