Activity › Forums › Adobe Illustrator › illustrator text and distort
Posted by Deleted User on May 18, 2007 at 9:33 pmcan someone help me figure something out. i know how to add a distort effect to text. It all works well…. but as soon as i rotate the text, it becomes more of the flag effect. i dont get the results i want. can someone please help me figure this out. thanks
Mike Gondek replied 19 years, 4 months ago 3 Members · 6 Replies -
Deleted User
May 20, 2007 at 7:31 pmAnyone out there….
Nolan Scott
May 22, 2007 at 3:27 amUsing Illustrator CS / OSX 10.4.9
Well, as far as I know, delete the
Mike Gondek
May 22, 2007 at 12:57 pmWhich distortion filter are you using?
I personally like to use envelopes and have found a trick that works incase you edit text, or in your case rotate. I just create a rectangle larger than the artwork, and then I apply OBJECT >> ENVELOPE DISTORT >> (CHOOSE YOUR WARP SETTINGS). Later I can slect just the text with the direct select tool and make change to the text, btu the distortion remains the same shap so I dont have to creat it again. You also have numeric settings with envelope, so you can do things like interlocking puzzle pieces distortion by flopping the numbers on your subsequent items.
Deleted User
May 22, 2007 at 4:42 pmim trying to bulge the text.
this was done in photoshop.
http://www.scotlandorbust.com/text.jpg
thats what im trying to accomplish.. easy in PS, not so easy in AI. im going to try your method though. it does sound a bit confusing..
Deleted User
May 22, 2007 at 5:01 pmi cant figure out your technique… please elaborate.. i made te rectangle over my text.. added the bulge to the rectangle.. but how do i get the text to conform to thte bulge of the rectangle. thanks
Mike Gondek
May 23, 2007 at 1:31 pmSelect both the rectangle and your text, then apply the envelope distortion to both of them.
You can later edit the text by:
Object >> envelop distort <>> edit contentsThe advantage to the rectangle (with a fill and stroke of none) included in your artwork, is if the size of your text changes, than the distortion will follow the same curvature if you change the font to another typeface, size, capitalize, etc. The rectangle acts a a bounding box.
